Fg compare Photo's some help needed???
Large Scale Basher
Reading the Rules!
birmingham
Hi guys, I was just wondering if any off you guys could take me some pictures like the once I have uploaded I would really be totally great full as i need to compare pictures with some other trucks to see if my truck is set up right as your once as am not as experienced as you guys are... Thank anyways, will be looking forward to seeing the photo’s :) And guys if u can see any parts in these photos that look wrong then please do let me know and I will take your advice on board ;):):););)
In the 1st photo it looks like the rod could be bent before it goes into the rod slide. Make sure it straight or it may bind.
Get yourself a rubber boot to cover the top of the switch. You can make one out of a balloon or buy one.
http://www3.towerhobbies.com/cgi-bin/WTI0095P?FVPROFIL=++&FVSEARCH=switch+cover
You can find them on ebay also.
See if there is an optional alloy servo horn for your model servo. It will help in the flex when you go to brake.
In the second photo, most people will not use a spring because there is too much movement. Using a piece of silicone or preferably nitro line is the best.
Here is a generic photo that shows what I mean:
attachment.php
attachment.php
In the third photo, I think I see the brake rod is bent. It should be straight and you can adjust it slightly by moving it back and forth to change its length and tightening the screw on the top.
I cant help but to recommend away from using that filter for off road use. Not one of the filters I have heard good things about specially if you run it bare like you show.
Good luck.. Great photos!
Good advise on the filter. I have the same as you so rather than spend on a replacement std filter set I just bought 1 of these pre filters & oil to keep costs to a minimum. Its a good snug fit & does the job.
http://www.rossmod.co.uk/store.php?value=6513&search=6&product_id=20260&return=store.php
I did enquire about an outerwares cover as well & they advised it wasnt necessary with 1 of these (these guys race FG's) but some on here run both. Its down to your preference.
hiya guys thank you so much for the advise i took it on board i fixed the problems and i started it today all what is left know is a re-tune thanks
