gary50
hi all sorry if im in the wrong department but hopefully someone can help
right my bro has bought a marder clone which has the crapest layshaft brake setup ive seen so we decided to change it over to an fg marder setup, anyway with me thinking all the engines are the same (23cc cy engine) i changed the gear plate and large engine mount and the layshaft is on the p**s,see picture
this is it with the origanal gearplate and mount on
for it to all line up it seems the fg gear plate needs to move back approx1.5mm
do i need to change the clutch housing?
we hav run it with the layshaft on the p**s but it destroyed the layshaft gear
he does have a fg chassis on the way that why we changed the mount as the clone has a oval washer set up on the bottom of the chassis
sorry if i don't make much sense but im sure you will get the jist of it
any help would be appreciated
