FG Marder engine exhaust oil ??
Ross
LONDON- IN SHED
Hi all i stared my fg marder ofter a year and i had a few problems with the engine i gave it a good clean and i was able to start it :D then ther was alot of oil coming out of the exhaust if you could plz help me and tell me what will this means it would help alot :) thanks
Ross
It could be that your pipe needs cleared. Over time oil can build up in a pipe after not running it it could have turned to a sludge. Use some alcohol and flush out the pipe. If your pipe is holding oil or has a considerable amount of build up, you could even gain some lost performance. Oil build up can effect how well your pipe resonates.
i tryed but it also drips oil from the manifold its not got the gaskit on it i was just testing it but i post a pic how much oil ther was running for a few seconds :(
well yh as i got the car off ebay about 2 years ago and just got another off ebay going to pick it up on sat so hopefully that engine will be ok as well it was cheap for a racing lorry for £100 with 2 body and radio stuff hope its not in a bad way :s thanks for the help tho :)
