FG Marder engine oil ??
Ross
LONDON- IN SHED
Hi all i stared my fg marder ofter a year and i had a few problems with the engine i gave it a good clean and i was able to start it :D then ther was alot of oil coming out of the exhaust if you could plz help me and tell me what will this means it would help alot :) thanks
Ross
A lot of oil is better than no oil :w00t: If its been sat for 12 months the oil may have been standing in the pipe from your last run out and all settled at the bottom giving the effect of too much oil. A few good blasts should clear this or take the pipe off, put a bit of petrol inside & give it a good shake with a hand over either end. If its very rich (possibility with the oil) it would be running lumpy and bogging so try re-tuning it & see how it goes. Did it run ok by the way?
its was ok i give it another go now it will need re tunning as i did not tune it then i got the racing pipe :S so it dose sound bad sometime and cuts off :(
