FG MB Pro ---> Marder!
tizdaz
Sunny Northwest!
hi guys :)
What would be needed to fit a Marder shell onto my MB Pro chassis, im not gunna be chainging the wheels or gearing will be keeping the bigfoot rims/tires on :D , just want to have the option of fitting a Marder shell as & when i feel like ^^
Is the roll cage the same for both models, looking at exploded diagram they are except the Marder doesn't have the front end of the roll cage like the MB Pro does?
im guessing body mounts too would need to be changed?
Any info much appreciated, ta :)
EDIT:
just looked into a bit more, seems id also need new smaller shocks, but i would want to keep the 2x shock setup for each wheel as on the MB Pro! but the front shock tower for the marder is only for 1, how could i get around this?
cheers :)
everything from the gas tank back is the same on all the off-roads. You would need the small side mounts (mounts the body where the steel side plates are. The front shock tower will need to be changed too. probably a bit more but that is off the top of my head.
