FG Monster & Duratrax FireHammer MT?
aqwut
Hello all,
I have a firehammer MT, and a set of FG Front caliper breaks. When I installed the braking syste, the bolts seems to rub on the front wheels a lot. What I would like to know is, are all FG Monster parts interchangeable with the FireHammer MT? I would like to upgrade to some Aluminum Parts...
did you add the wider wheel squares? I put the brakes on my fh but also added aluminum knuckles and they work fine. I know the fh stock plastic ones are more like the on road fg
no, everything is stock.. I don't know much about 1/5ths scales yet... I only know Firehammer and Baja.. that's about it...
You can get wider squares and longer front axles so the front brakes work. The firehammer rims have no offset like the Marder Race and Leopard race rims do (6105/01) .
As for MT rims, I know the FG's have no isses since they also hae a good offset. I guess the Firehammer MT rims do not have this too.
you need some extended axles? I have extra axles that came with my brake kit, and 4 or 6 wide squares too. at the rate I am working right now I'll never get to play and wear anything out anyway. I'll look for them in the morning and show you the difference. I didn't use them on the semi as I wanted it to stay the same width. and I used a front set on the back as well, so I believe I have 2 sets of new fr axles... there are a few different front brake kits
Hey Thanks Guys... I will try to find some wider wheels axles.. but I don't' know whwere to start.. towerhobbies..?
how much do they run, and where to get them.. Thanks again.. I wish I knew this earlier, else I wouldn't have trim some of my body off... :huh:
