Fg mt front wheel hubs ?
Large Scale Basher
Reading the Rules!
birmingham
hi i am in need of a front right wheel hub as the thread is F**ked on it and its making the wheel beng... i know i am being a bit off a Arse but does anyone have one that they coud let me.. helping a Buddy out.. ive checked on ebay there is none and i don't want to buy 2 are the other one is fine and i thought i mite aswell check on here if someone has one around that they don't use i would really be great full :kiss::kiss::kiss::kiss:
If your talking the square, just drill it out, re-tap it bigger and set a bigger grub in it.;)
if i do that the the bigger screw will not fit in the ball joint ..... forgot to meshion!!
I have to alloy hubs right and left but i don't have no insurts for them and plus i don't know how to connect my diSK breaks to the hubs !! THAT WHY I THOUGHT MITE ASWELL JUST GET SOME NORMAL ONCE BUT IF SOMEONE CAN HELP ME FIT THEM THAT WOULD BE GREAT :)
I don't think I'm following you?
Are you talking the aluminum wheel square the rim fits over?
If I am tracking with you and it's you don't think the larger grub will be flush with the top of the squar. You need to file or dremel down the grub bottom to fit the length you need.
Sorry bud I am on bout the acual hub the treads faked on its where the big screw goes from the end off the arm into the hub and it holds it in place that tread has expanted and it keep making to tyre ment and move
are you following me know :)
Do you mean the Front Upright?
http://www.davesmotors.com/s.nl/c.885035/n.1/it.A/id.1807/.f
If so, the upright has a metal ring in the inside. Buy a new bolt and locktight it back into the ring. If you buy a bolt too long just size it the same. Is the hole that stretched out on top? The rose joint ball should counter sink enough to keep it from moving.
If thats not what your talking about. Sorry, I may need a photo. :white-flag:
