cycleoneoff
I was running it for about 20 min and opened it up for about 20 yards and noticed it was stating to bog and then it just died out. I immediately tried to restart it and it would not unless I put the choke on. I did notice that there was a lot of pressure in the tank. I've adjusted the carb to Low jet counter-clockwise to 1 and 1/4 turns open and high jet counter-clockwise to approx 1 and 3/8 turns open. I check the fuel filter and it was clean. The plug is perfect and it seems to have plenty of compression. Any help would be great.
- I have to put the choke on to start even after its warmed up.
- When I turn off the choke the engine will run at a high idle for about 20 sec and die out.
- If I gas it it will bog and die out right out.
I checked for a air leak and found after it dies out if I spray starting fluid in the manifold area it will fire up for a second or two. I found the head gasket 7306/8 is ripped and pop out.
