fg on mcd
FG wheels has a 18mm square hub, FS as a MCD clone is also 18mm square, I would belive that FG wheels can be used on a MCD.
1.The MCD evo 2 buggy and evo 3 sport monster has longer stub axles.
2.The MCD evo 2/3 rally and evo 3 comp buggy or monster use standard size stub axles.
In order to fit fg wheels you need No 1. due to the offset of the fg wheels.
Basically the longer stub axles give you that extra thread to tighten the wheel nut on. Without the need to drill or grind the wheel.
The shorter stub axles don't show enough thread through the wheel for you to put the wheel nut on.
Hope that makes sense.
i have fitted a set of fg wheels to a mcd but you have to drill a bit of meat out of the centers[about 3-4mm]to get the nut on enough
