fg on road drifting set up
renbar
kirby cross essex
hi guy whats the stock gearing for on roads mines running 24/40 but ive got a brand new set for the bug 20/44 are these to low,i want the car set up for drifting so need it to spin up rears as quick as poss and keep them spinning but i need less grip on the rear tyres
Get an adjustable clutch mate and get really hard tyres like the GRP 'd'...
Brad.
im running a adjustable fg 4 block clutch the tyres i was running were pmt kronos 5 on the front and 15 on the rear[may have been other way round]but ive got a few a's b's c's so might get a pair of d's
on the kronos the higher the number the harder the compound. for handling you should have a softer tire in the rear, for drifting do the opposite. the trick with drifting a 2wd r/c is you don't want to go with the hardest tire possible in the back cause the car will just go in circles. you want a hard enough tire that its not getting the best traction, but you need something that will have some bite to keep in controlled. being you have a selection of tires try some different combos out. whatever you end up doing, don't expect a pair of tires to last more than a tank of fuel.
as for gearing, id stick with stock. you need some wheel speed to get it sliding properly, the 20/44 will break the tires loose very easy but the thing is going to top out real quick and you wont have any wheelspeed.
