fg parts
helimad2
gainsborough lincs
im just wanting to know if its worth useing alloy parts on my baja for like general thrashing around the fields and few small jumps where we go or it is not cost worthy to do so ,any of you have any thoughts on this also looking at poss changing transmitter i got my fg out fit preowned and it came with a hpi hand set i don't think its really what should be uesd with these buggys any recomendations would be more than welcome , are there any clubs fairly local in this area i should know about too thanks .
here you go dude:
a lil guide i put together :)
Clicky
as for radio set/servos, no idea what the hpi one is like? but the norm nowadays is 2.4ghz handsets although i do still use 40fm personally (Sanwa Gemini II) with multiplex servos :)
& local clubs, no idea sorry mate, im from North West & theres not really a largescale club near me, although ive just met a bunch who meet up not far away from me :)
best bet make a post here ;)
here you go dude:
Clicky
thanks for that ill look into this and get something sorted mine has front disc brakes but need t obe checked out
My marder is all standard plastic & it holds up very well - not broken anything yet!! The plastic is better than you think IMO. Adding ally adds weight :2guns: get some front brakes either cable or hydro & a tuned pipe for a start :cool:
I posted a thread in the electronic section for an Ansmann W3 2.4ghz set for £53 at JE Spares. This is an excellent set by all accounts. Might be worth a look.....
What Andy said is right.The plastic does do a good job and will hold a poop load of abuse.If you want longevity go for alloy, I have used both and knackered the plastic.The alloy is 60% stronger but when you bend it,you bend it! and it takes a few quid/bucks to straighten it or buy more.
If you are going for a jump truck/buggy buy alloy.If not stick to a reputable company that sells after market parts.
http://www.rpmrcproducts.com/products/tools/index.htm
Good luck
J.
my baja is full plastic, no upgrades besides a pipe and I haven't broken anything yet but I have only had it for 4 week. have done some pretty big jumping and had a few spills but no problems yet.
i will be getting alloy engine mounts soon though.
I had a big off & bent the chassis but all the plastic stayed intact. If the plastic does break its only buttons to replace rather than big $$$$$. There are +'s & -'s to both. A big part of it is whether you want bling :cool2:
the biggest - to alloy is the price and also the weight mines all alloy cost me bundles but its bash proof would i do it again no id keep it mainly standard apart from eng mounts,diff mounts+diff,rear upper arms, gear plate thats about it and of course metal gears
bits ive buts (stock) on my MB Pro are:
Rear shock tower (getting front & rear alloy upgrade soon)
Melted spur (replaced with steel)
Stripped thread in front hub (replacing front & rear hubs with alloy soon)
Ive had it 2 years & apart from the melted spur, the others ive done in the past few months! :(
Only just fitted a DOM pipe (ta james \o/ ) not been out with it yet.. fkin weather :( ..only things im gunna upgrade after the above is engine mounts & front bulk head & front cables :)
