FG Sedan & F1 demensions
vadn1
Houston, Texas
FG Sedan & F1 dimensions
Can someone post the dimensions for the following
FG Sedan with 320i body mounted - Length, Width, Height
FG F1 Sportline with body and front and rear spoilers mounted - Length, Width, Height.
I need to find some plastic tote boxes this evehing for transporting both cars to the local track. I will not have access to my cars till late tonight.
The following measurements is what i use to transport 1x competition evo 08 535 with BMW 320i body shell
L:1000mm W:500mm H:400mm
Troy
This may give you a few ideas:
http://rc-car-online.de/shop/en/pro...approx-535-mm-width-approx-400-mm-1-pce-.html
http://rc-car-online.de/shop/en/products/fg_8179-8179-body-set-bmw-m3-alms-painted-2-mm-set-.html
Don't forget where you see the dimension for the bodyset, that's the complete bodyshell only - extra height required to account for the height the shell is when mounted - typically another 5-10mm depending on application.
Al.
LOL the dimensions above is the exact size the car arrives from rc-car-online.de
Troy
TBH I didn't get your 500mm width Troy.
Then I did the unusual thing of re-reading the original message!
Car's are typically 900mm x 400mm x 300mm ish, so just add a bit here and there for carriage I suppose, as you did.
Al.
