Sharkey
well they arent, they are all based off the same engine from 23cc to 30.5cc. just think of a small block chevy, 267 to 400ci, but you have a 396 big block. the term bigblock and smallblock really means nothing in gas r/c.
..................You pull the big block NTC-3 off the track because you are bored??? Is that because you can't handle it?? How can you be bored with that ?? Unless it is not set up properly and you can't drive it. I think 4wd would be better on a unprepaired surface.we already have overpowered 1/5 scale onroads. i run a cy26 with a meilke side power pipe in my sportsline, its got too much torque. yea 4wd would be handy to put the power down, but why? the problem with going to a big motor is a decrease in rpm and the power band is moved way down, so to combat that you need taller gearing to get the speed back, then you have lost the bottom end and its hard on clutches. bigger just isnt always the answer, a nicely built 23cc will be more than enough power in any onroad car.
ive got a nitro tc3 (1/10 scale touring car) with a rossi .21, the thing will dam near hit 80mph (roughly 130km/h), i cant throw enough gear at it, thing is after 5 laps i pull off the track cause at that point im bored.
