FG Square Hubs for Baja?
owen_primalrc
Hello, I am sure some 1/5th genius can answer this in 2 seconds.
Is it possible to mount GRP square hub wheels/tires on a Baja? The touring car GRP wheel and tires. I know they are comically small for a Baja, but I think they will have the best on road performance and would like to give them a go.
I have searched the web far and wide but have not found what I need. Does someone make an adapter?
Thanks!
there used to be adapter kits available a few years ago mate,
but they were fg to hpi adapters if i remember correctly,
i d also recall someone on the old baja uk forum modding some fg squares to work on a baja but that forums been defunct for years now,
i don't think it was the best or most reliable solution cos you'd need a 12mm hole in a18mm square drive, plus a short 18mm drive pin and slot cutting into an fg drive square,
edit; after seeing monsters link below the home modded ones i saw on the old baja uk forum must have been made from mix of parts and general bodgery :LOL: ,
