FHMT body on shengqi humvee...NOT
Brent1972Indy
Indianapolis, IN
My fhmt body just came UPS and it does not fit my wheel base. WTF!
I was thinking this was a near replica of the fhmt.
Can someone please give me the center to center measurement from front to rear rim on the fhmt?
SPECS: Vehicle-
Length: 27" (686mm)
Width: 20.9" (530mm)
Height: 12.5" (317.5mm)
Weight: 21.75 lbs (9.86kg) ready to run
Wheelbase: 18.75" (476mm) wheels on-center front-to-rear
Front Tread: 15.5" (394mm) wheels on-center side-to-side
Rear Tread: 15.9" (403mm) wheels on-center side-to-side
Front Track: 18.75" (476mm) outer edge of tires
Rear Track: 19.1" (485mm) outer edge of tires
Ground Clearance: 3.1" (79mm)
Tires-Front and Rear: 7" (144mm) outer diameter x 3.16" (80mm) wide
Gasoline/Oil Mix: 25:1 for break-in (4%) (5oz per 1 gallon)
40:1 for normal running (2.5%) (3.2oz per 1 gallon)
Body-
Length: 19" (482mm)
Width: 7.3" (185mm) at rear wheels (widest point)
Height: 5.1" (130mm)
Its not quite right on the FHMT either.
attachment.php
Looks about how it fits to me.
That's exactly how they look man! Mine is the same way.
No big deal though, they are cheap and take some pretty good abuse. My next body is going to be an FG though. Whether that wheelbase will fit a FHMT, I don't know, but I really want a Monster Beetle Pro body.
Clubin- can you show a pic of your Beetle with the body off? I want a good look at the body mounts.
