MONSTERTRUCKMAD
- AUSTRALIA
Hi people,
Who knows if these Duratrax FireHammer/MT parts fit the Shengqi Hummer?
- Duratrax Hinge Pin Set Front FireHammer/MT DTXC7994
- Duratrax Spur Gear Mount FireHammer/MT DTXC9317
- Duratrax Spur Gear FireHammer DTXC9394
- Duratrax Pinion Gear 14T FireHammer MT DTXC8891
- Duratrax Air Filter Complete FireHammer DTXC4019
- Duratrax Arm Set Front Upper FireHammer MT DTXC9534
- Duratrax Arm Set Front Lower FireHammer MT DTXC9518
and do most Duratrax FireHammer/MT parts fit the Shengqi?
Should I change the pinion and spur gear from plastic to steel?
I gather from what I have read the standard pinion gear is 14T and the spur is 48T. Please correct me if I'm wrong. What will happen if I change the pinion to higher number of teeth? and if I did this would I have to change the spur gear to?
I know that's a lot to ask but if you can answer a few of the questions that would be great.
Cheers and have a great weekend.
