FlySky it4
ika
Hi,
Have you some experience with FLySky it4 on long time use?
As I know it has problems after couple of month usage.
Thanks
rcgasser said:
On year 2 I have not had any issues with it after they finally fixed where you can bind more then 1 car so after that no problems.
How did they fix that problem? I wanted to get that radio but held off because of the problems people were having. I even read something about soldering on a new chip to fix the problems.
As i know , now it comes already fixed. So no soldering needed.
Anythink else,befoure to buy?
Hey can you run a kill switch w\o issue? If so, which one are you using? Thx
ika said:
As i know , now it comes already fixed. So no soldering needed.Anythink else,befoure to buy?
Not sure how you will use yours I have 7 cars on the radio so I drive all day so you may want to get a second battery if you turn down the screen on time and not looking at the screen much in a day and only using 1 car you will be OK with just the one battery.
