FLYSKY radio transmitter for a King Motor 1/5th Buggy, help needed to setup brakes.
buffy
hey all, i just received my Buggy and iv been playing around with my remote control settings and cant figure out what setting i have changed that`s affecting my brakes not to work?
Cheers
Check the trim on the channel of the remote that controls braking and throttle. Have you, by chance, removed the servo horn that controls the throttle and braking?
ok cheers,what do u mean removed the servo horn? whats that?
the problem i have now is when i accelerate the motor fails(konks out).
im aware of the reverse mode on the controller and have set that up but my engine still seems to fail when i accelerate. what would cause this?
Sorry for the delay. The servo horn is the part that fits onto the throttle and brake servo. If it is out of place it could have an effect on the braking!
ahh ok cheers, ill have a look at that, also the failsafe does not seem to work now for some reason....any reason for it just to stop working?
Dose the kill switch still work?
If so dose the fail safe run through its normal LED operation I.e 2 blinks per second for it to run and 1 blink a second won't run (that's just an example all fail safes are slightly different but all have the same principle) ?
Got it working cheers but going to get a bee failaafe still
