frequency swap
kryptonite5b
philipsburg pa.
can you use hitech 75mhz crystle with with an airtronics 75mhz radio? i know that futaba crystles wont work. trying to finally put my airtronics to use, but short on crystles.
75mhz chrystals should work with any brand 75mhz radios and receivers.
as long as the tx/rx is 75 mhz, and the chrystals are FM 75mhz on the same channel and you should be good.
