KrashKrieg
My Front center diff cup has been beaten to death by dogbone pins....
A while ago I ordered part # 07146 Center Drive Cup 2p
Finally installed it, took it for a run and the front dogbone dropped out...
Some closer inspection reveals that my original front cup is 26.06mm tall and the part 07146 is 24.06mm tall...
those 2mm are enough to drop the bone out
I looked at the other center cups and they all appear to be 24mm and only my front one was 26mm???
I looked on RedCat site parts manual list for XBE and found part # 710022 ...Center Dogbone Joint cup
so I'm looking for the differnece between part # 07146 and part # 710022
or any info as to what happened....dogbone I believe is stock @ 128mm
Temporarily I shimmed it out with a 1.7mm washer (8mm hole) but the grub screw doesn't exactly line up with the 'flat'
As always, any insight is appreciated...
