front cv /dogbone
andyken
New Hampshire
And the list goes on...
I need front dogbone cv joints for my xb.
Are there any upgrades?
Guess i need to measure mine, now there is 128 and 130mm fronts?
I would get rid of the cv joints and do rear bones and hubs on all 4. It will be much stronger and easier to maintain,less parts to lose
Couldn't agree more. I am running all dogbones on mine and could be happier. Only think that happened to me was I lost a dogbone due to a suspension arm breaking during a crash but a dogbone leash would save that. Cvds theres a lot to maintain with all the stuff you gotta do already. The simpler the better.
you say that dogbone be better than CVD ?? :confused:
The cvds require a lot maintanance, it could be that I didn't boot and grease them but with my 30.5 esp head on my dune runner it just chewed my cvds up that's there was huge grooves on the eyelet of the cvd.
cvd's are superior for transferring power because the tolerances are tighter and it keeps the loaded parts at the best transfer angle which makes them more efficent
however the cruddy conditions the cats get run in can ruin them and cause allot of unnecessary wear a boot really is essential to promote the long life of a cvd
there are cvd parts available for other cars with improved tolerances
but all the ones i've seen would probably require modification to fit them
the quick fix is to run dog-bones all round as that reduces the
maintenance requirements some people have said it improves strength
but that shouldn't normally be the case* as the lash and shock on the dogbone pins is greater than the captured cvd pins simply because they have
more room to accelerate and then bind when the diff is active
as an example, try a one inch punch versus a three inch punch on a solid
object where you have less space to accelerate the shock delivered is
far lower ( seriously, try it. ) just don't blame your knuckle bruises on me!
if the cvd pins are also properly lubricated with a thick grease the lash shock is again reduced because the grease will have to flow out of the way on impact
and will act like a damper
so the technology is good, but what's going wrong?
-people don't maintain their cars well, a thick grease is really required here
-*our cvd's aren't built to the best tolerances, or out of the best materials
and crack far easier than they should
-they don't include boots, so you want to protect them? it's third party time
personally i'm looking into making an entirely new part rather than use the available ones because they just aren't upto the job in my opinion
something like:
http://www.nutechracing.com/english/ProductShow.asp?ID=866
appears to have tighter tolerances, if i can make it fit
or if i really have to, i may build my own from engineering stock:
http://www.indiamart.com/universaljoints/precision-universal-joints.html
if i manage to get something workable, i'll keep you posted
since we are talking of CVD I ask a question to all of you ....
Have you ever noticed the difference between the CVD for MT-TT-DuneRunner?
are both original spare parts code 050009
Yea I have noticed that!!! The stock ones that came on the mt and dune runner were both different like in the area you got circled
Also some of mine didn't have a set screw on the tip for the pin it was just solid steel no way of removing pin. I believe all parts under a part # should all be exactly the same
I just rebuilt my CV for my TT with 5/16 round stock and hpi A arm pins.The 5/16 round stock was cut drilled and taped like the stock ones in my TT,then i heat treated them.
The pins i made out of the A arms pins out of a hip savage or hellfire,I had them kicking about from the 1/8 scale days.Just cut to fit the pins in and grind a flat spot for the set screw.
I did the because i was in a jam,the shop in town had not CV or dogbones to fix the truck,and it was going to be 2 months before he put in a order.
i ordered some boots, hostile maybe. i don't remember the name right now. i planned on running them over the cvds w/lucas red n' tacky #2 grease (grease of choice for just bout everything, also water resistant) & then making the 3/4" copper type L diff cup covers. this sound like i'm on thr right path? i know the boots will rip. nothing new there for me.
