front steering tierods
STEFANO-M
Lucca
Hi guys,
Can someone post a picture where is possible to see the connection of the steering tierods to the front wheels?
Becouse I have put them out and now I have a dubt for install again...
Other question.
I am tryng to do the first radio set up for my truck on my work table.
I put the steering servo in the middle, (servo arm but the right wheel is no parallel with the right (watching from over on the truck)
I have chenge the lengt of the steering tierods to bring the wheel parallel. Now the right one is more lenght about 5 mm respect the left one
Anybody had the same problem?
Have I done the right thing???
Thanks in advance for your experience
Is it possible to take a couple of pictures of your tie rod set up? If you have them adjusted evenly then there is no reason for the wheels to be out of alignment (assuming not connected to the servo). :)
This is mine if it helps, although I have the after market alloy hubs fitted so won't be exactly the same???
Make sure you set your servo to center. Turn on the radio and reciever. Then shut it off and install the servo horn. This will make sure it is centered. After that you should be able to make everything the same length.
Photos will help.:)
Thanks to all.
I forget the foto...
What ca I see in your picture is that the steering teriods are connect on top of the wheels hub...
I have wrong . I have connect them on the bottom..
I have to invert it
Thank you again guts
