KrashKrieg
I hadn't even started her yet and I installed the 813 with Shredstack and HPI filter...
Is there a way to change the direction of the fuel jets? They are angled completely different than the stock. I had to pull the lines up through the tank a good inch or so to connect them.
My guess: is you can't change the angle; the way the lines run is OK and I should get longer fuel lines so the clunk hits the bottom of the tank.
Thanks in advance...
