Fuel tanks
renox
Hello guys
i am new in this forum and i have a question
before one year i was have a rovan baja 5b and when i buy he said after 15 full fuel tanks i need to buy a new motor he said "this is baja 's )
so i ask if its true about the kingmotor baja 5b
Thank you for helping
Hi Renox,
You could get up to 150-200 full tanks out of an engine before replacing it.
What will happen is the ring will wear and the bore as well, thus losing some compression.
This can be resolved by changing the ring from time to time.
The bearings might have to be changed after perhaps 30-50 tanks.
DO NOT mix fuel with a ratio of more than 32 petrol: 1 oil.
90% of people use 25:1 to err on the safe side - not ruining the engine as this is the oil that lubricates the engine as you use it.
