fuel vent
Thx guys I think I'm gonna go with the kit the less I need to think or customize things the better off I will be and the less likely I'll break something
It's more work but it is a neater install if you vent the tank directly.
Super easy mod. Good luck. :)
Since you're going to get the kit, consider getting the brass fittings, as well. They make fuel line maintenance a lot easier and cleans up that area a bit. They fit kind of loose in the grommet, though. To remedy that, all you need to do is add a small piece of fuel line to the barbs at the top of the fitting. Very easy.
