Fuelie factory carb tuning
The base settings are:
1 1/4 out (low needle)
1 1/2 out (high needle)
To get to these settings turn the needles all the way in just till they stop. Don't tighten or you will damage the needle. Then back out the needles the desired number of rotations.
Every carb will be slightly different.
You will want to do high speed runs leaning to increase performance.
Small 1/8 or less turns at a time.
After every adjustment do a high speed run and check the color of the spark plug. You want a nice brown paper bag color. Any white or ash color and you are way too lean. Black you are too rich. Here is a plug color chart. http://www.dansmc.com/Spark_Plugs/Spark_Plugs_catalog.html
Start with the low lean it just a bit. The rpms will increase. You can lower the idle stop screw. If you can't get the idle to drop you are too lean.
After you get the low set where you like it you can move onto the high needle. Remember to check your plug after you start leaning the high needle.
Not a trail but you should see it when you hammer the throttle. When you see a lot of smoke you are on the rich side. The base settings are on the rich side. They are "safe" settings. Not really for performance. You use those for break in and a starting point when you begin to tune. If you have trouble getting it to start, it is always best to go back to the base settings to get her running. Tuning takes a bit of practice. Once you get it tuned you can leave it alone. You will need to be a little richer in cooler weather as the air is more dense.
A side note if you run synthetic two stroke oil you will have less smoke. Its better for the engine and makes driving more enjoyable.
If your worried about not having a choke you can put your hand over the intake and pull 1 time then one without the hand it will fire up no problem , in a seance your hand is the choke lever
Once you have it tuned it does start easy. My XB sat several months with out being ran. Filled it with fuel, primed it. Started on the 3rd pull!
