Fulie 30.5 info
I've used a Fulie 29cc after running a 26cc and I noticed a fairly nice improvement to low end punch with a bit more top speed. I'm not sure about the 30.5 but I'd imagine you'd get even better torque and top speed would increase/decrease depending on how you geared it.
Are you able to find a good deal on the 30.5? If you have the money, why not just get a G320RC engine and be confident that you're buying quality.
30.5 stock ported is what I run in the heavier 5ive T. Does donuts on clean blacktop! Not really a high revving speed machine though....I would lean toward a ported 28.5 cc or 29cc in a DBXL as it revs to the moon and you don't need near as much torque as I do....The 30.5 would require a re-gear IMO.
I run stock Fuelies 30.5cc, not a bad engine, tuning is all in the carburetor.
Its a basher engine, if it pushes the X2 no problem with acceptable top end, it will definitely move around a DBXL.
You can check on getting a full crank with a bigger displacement top end.
