full race lorry fg
sprinkler
New Member
hi everyone i have a full race spec fg lorry with 100%alloy hyd brake all round full comp chassis all the right bits ,also a fg marder all alloy and carbon i do not use the lorry anymore and was wondering if i got another marder chassis
would all other bits swap over and make another off roader comments gratefully received, thanks mark
The parts should be ok for a different platform..like Fg marder...The marder has a
shorter chassie....than your long chassie now for your lorry...
Ask pipeous..he has a lorry....slawhammer
it's all the same... my avatar is a lorry... only thing to change will be the front bulkheads. the lorry has a flat chassis, marder has the kick up. so the lorry bulkheads are taller in front and the bottom part that bolts to chassis has an angle.
you will have to use the dif risers or get a new large motor mount for off roads as well. dam as I type I remember the little things... also the clutch housing is different so you'll need clutch housing and motor mounts. and roll bar if you need them, body mounts, side guards..
trade you a set of almost new buggy tires for those lorry's? LOL. I want my beetle to be on road.. though it'd be across the pond.. I call my truck a semi ;)
thanks for all information got some thinking to do if i break it i will swap the tyres with you i will put some pictures on
mark
