Fullforce
We've been busy as can be with this new truck in the shop! Had been holding off on product releases till this stuff had already started to ship out to dealers. Boxes have been going out since yesterday so expect these goodies available at DDM, LargescaleRC and your favorite shops within a few days.
Our Losi Five-T products are now available at TGN!
L5T004 LOSI 5IVE-T FRONT CHASSIS BRACE $42.00 Coming soon
L5T005 LOSI 5IVE-T REAR CHASSIS BRACE $42.00 Available now!
Seems like everyone it putting our chassis braces for the 5ive-T now. Well, just so we wouldn't be left out here is our versions! Just about every other manufacturer is going for the race/light weight product so we wanted to do something really different. We're going after the ultimate strength and durability! Our braces are machined from solid billet 7075 T6 Aluminum. As far as I know, we are the only manufacturer to put these out with this high quality material.
Expect our usual precision machine work with the nice clean radius edges too. These things are built to take all the punishment you can dish out and never worry about bending one of these heavy duty braces!
Our new windows are made from a Poly material that can be laser cut! This stuff is super tough and can be painted! Leave these clear or paint them to your body color scheme. The cut on these is super clean for that precision fit! They come with hardware, window clips, install instructions an our standard product small decal sheet.
L5T006 LOSI 5IVE-T FRONT WINDSHIELD $12.00 Available now!
L5T007 LOSI 5IVE-T Rear Upper Window $12.00 Available now!
L5T008 LOSI 5IVE-T Rear Lower Window $16.00 Available now!
L5T013 LOSI 5IVE-T Pit Box/Screw Kit $36.00 Available now!
163 PCS of the most damaged and lost hardware all in 12.9 Grade alloy plus spare wheel bearings!
L5T014 LOSI 5IVE-T Axle Caps $5.00 Available now!
Plastic caps that pop into your open axle ends and prevent debris from getting in there. Cheap upgrade compared to the more expensive enclosed nuts!
L5T010 LOSI 5IVE-T Aluminum Servo Clamp Set $18.00 Available now!
Although you can use our normal 5th scale clamps on this truck, we are making a new version with M3 slots that will fit much tighter! We'll also package them up in sets of four with new longer M3 screws!
L5T019 LOSI 5IVE-T Aluminum Swaybar Clamps $20.00 Available now!
Available in sets of four, these machined little clamps will be a direct replacement for the plastic stock ones.
We've also got a couple of existing items from our Baja line that are a perfect fit on the 5ive-T!
5B004X HI FLOW FUEL LINE KIT $20.00 Available now!
The 5ive-T has the same tight fitting and restrictive grommet on the fuel tank that is present on the HPI Baja trucks. Pop in our kit with its machined brass elbows and high quality Tygon fuel line and never worry about fuel restrictions!
5B008 LOSI 5IVE-T STAINLESS BEADLOCK SCREWS $8.500 Available now!
For you guys running on the beach or in the sand, you will love having some stainless beadlock screws! We give you a full pack of 100 PCS!
Still more goodies are on the way! Will keep updating this list as we put them out for you!
Enjoy
Romean
FFRC
Updated 12/28/11
Enjoy
Romean
FFRC
Updated 12/28/11
