Fusion LX60b Pro
tizdaz
Sunny Northwest!
Hi guys, i got this charger, but im not too sure what settings to use!
i have a 5000mah 6v pack.. this one: http://vapextech.co.uk/acatalog/info_147.html
my charger does cycle charges.. so what ive done is set the discharge at 1a which is the highest setting & i set the charge rate to 3.5a (max it goes to is 6a)
Are these settings ok, im guessing with my battery pack i could go upto 5a as its a 5000mah pack, but didnt wanna over do it on the 1st couple of cycles, Also i don't know if ive set the charger correct.. atm its got the elapsed time ticking away with the D symbol (to indicate discharge) flashing so im guessing its working?
How long does it take roughly to discharge?
atm the display says:
D > C (The D is flashing which indicates discharge?)
59:46 (Time elapsed)
00752 (this keeps going up slowly but have no idea what it is, it started at 0 i think?)
NM - 0.76A (guessing this is the actual discharge rate?)
6.540V (this stays pretty much the same & not quite sure what it means)
I have the manual but its very vague & until this charger i just had a basic Delta Peak so this is all kinda new to me :s
any info much appreciated! ta :)
