futaba 3pm mx
also what is the ppm and hrs mode i'm runing all hitech servos in my truck 5745's and 645mg throttle
The HRS mode is for digital servos. It runs the TX at a higher frame rate. It will also keep the failsafe setup in memory, you don't have to reset it every time you turn off the TX/RX like you do in PPM mode.
thanks for the reply do u suggest to change the setting to the hrs mode will my servos be ok with it
I don't think the 645mg is a digital servo, right? If you run in HRS mode and don't have all digital servos it could damage whichever one is analog. Get a digital for the throttle and then you can run in HRS mode. I ran a Traxxas 2075 waterproof but I'm sure someone here can point you to better one.
ok thanks i guess i'll leave it on ppm just got to remember to set the fail safe every time i run it lol
