futaba 4pk
I have heard it is the one to get.
Still whiting on a perviou thou. It is $$$.
Great radio, expensive but it is made by Futaba, so it is good. If you want one just go and buy one. I wish I had a 4 channel, i need it for my FG, 1 channel front brakes 2nd chanel rear brakes 3rd channel mixed with rear brakes and 4th channel diemaster kill switch. I have a Spectrum DX3R and I should have held out for a 4PK.
My only complaint about the 4PK (aside from the price) is that it is not module based like the 3PK. With that expensive of a radio, I really think it should give you the option of modules.
well i recieved my 4pk sat.
set it up and ran about 3/4 of a tank with it.
looks good so far.
light weight
appearence is great
finish is exelent
programing takes a little reading but it will come to you after you have read it a while.
range seems to be real good.
feel is exelent.
control are easy to use.
only problem i have had with it was one of the knobs on top of the tx fell off.
lost it but a replacement is on the way.
you can use ether the three ch or four ch rx with it.
one thing that i find to be a pain is the off on switch can be used in two positions .
push it to the left and the display comes on but you are not sending out a siginal.
push it to the right and you are transmitting a signal.
i tried to bind the tx and rx together and it would not bind.
than i discovered that the switch was on the left side position.
a quick slide to the right and it bound perfect.
yes frumpy i still have the 3pm and i am going to keep it just in case then 4pk takes a Dump.
179.00 insurance.
oh well it's only money
can't take it with you.
Dirby
make sure you get a good caerrying case for the 4pk.
some of the cases are not deep enough and when you close the cover the top hits the steering wheel.the Hcap 2010 at tower hobbies is deep enough for the 4pk.
this is the one i have.
go to tower hobbies and type in the serch box
HCAP 2010 and you will find it there.
fits perfect.
Dirby
