Futaba Megatech 3PM 2.4GHz FASST controler
Based on what I read, the answer is "YES"
Futaba Megatech 3PM 2.4GHz FASST Combo
The FASST (Futaba Advanced Spread Spectrum Technology) system that did wonders for the 3PK is now available on the three-channel 3PM computer radio! The 2.4GHz modulation works directly from the transmitter, so theres no separate module to plug in.
Constant shifting within frequencies, no more signal conflicts or waiting for a frequency to open up!
Auto-Detect, instantly determines whether HRS or PPM mode is active in the transmitter. Fail Safe, for both the transmitter(in case of interference) and the receiver (in the event of low voltage).
A wider range, for larger tracks.
Special ID code, prevents glitching by not accepting unwanted signals.
Features:
•R603FF 3 channel receiver
•Condition switches
•Alarm buzzers
•LCD screen with high intensity blue LED monitor
•10-model memory
•Model copy and clear functions
•Model naming
•ABS braking
•Brake mixing for large cars
•One-channel program mixing
•Steering and throttle exponential
•Servo reversing on all channels
•End Point Adjustment (EPA) for all channels
•Multi-function timer up/down with 100-lap memory
•Steering dual rates
•Throttle ATL
•Digital trims
•Function select dial/switch
•Steering speed
•Charge jack socket
