G320RC doesn't fit on the Losi 5t!
cocoda74
I received today the new G320RC!*
I mounted on my Losi T5 but the Reso touch the Drive Shaft so i rotate it 180 degrees.*
And the inserts doesn't fit, i don't why!
You can see it on the picture!
Have you any idea or can i leave it
Thanks for your Help!
Losi needs the modified clutch case, Fan Cover swapped to a CY one and the clutch holder also swapped for CY to give you the correct fitment
Man I wish I would have saw this video before I installed my G320 on my dbxl. I had to make the original holes in chassis to make it work. Can anybody tell me where to purchase those washer looking things in the picture above?
A Main Hobbies online has them. Just go to their website and do a search for Losi 5ive T parts. If you are running a 18T gear then you'll need the ones for 18T and if you are running 19T gear you'll need the 19T ones. Good Luck!
Ok thanks for the info.
