G320RC, G340RC, 30.5 full mod Reed?
designed2survive
MA
obr pro stock gets my vote , thats solid, easy tune, and reliable. plus super stroke it and full modded head easy 7.5hp.
the case feed mills are definitely more finicky than carbs on the head. if you are already beyond "regular" 2 stroke then reeds are next and do crazy power.
Will the stock transmission resist the 8hp engine? Also, I noticed that OBR charge extra for "sealed clutch housing". I'm a bit confused... isn't the vented clutch housing better than the sealed one?
The sealed was made for the dunes, to stop sand from getting in there. If you are just bashing around in dirt, then you don;t really need the sealed version.
Alright guys I need your help. To make this worst, I just saw that the ESP G320RC is on sale as the DDM Deal Of The Day for :
ESP G320RC (with Redcat clutch) $404
ESP G340RC (with Redcat clutch) $479 which is the same price as a an OBR G340RC Full mod
Now the question is OBR or ESP? And why? I need to make a decision before tomorrow morning. Thanks!
i had motors from both they're both good sources,
OBR has been everything they said they where holds compression 150+hours , screaming topends, easy tune.
gear will tolerate more than what is usable for weight and application.
if either is changed expect breakage... if you where to put 15lbs. of tracks and 12hp 460 on i would expect to break when you are pulling ur kids around in their wagon....but it would pull like mad for a little while!
or terrain shock load like rocks and wheel deep holes...that will break things.
Thanks guys. Pulled the trigger on one of them! Will be here tomorrow! Until then you get to guess which one it is! :)
If only Ol'Fart would update his website so I can get the front and rear diff housings :confused:
