G340 reed OBR
bongo fury
In my living room.
Have been using this in my Dragon Hammer for some time now and had it pretty well diald in. Up to now it has run like a dream. I was using it at MMR raceway yesterday but today i just cannot get it started. I have removed the kill switch, i have checked for a spark which i can confirm i have by the the electric pulses that shot up my thumb and fuel is definately getting in. The exhaust is clear and the air filter is new. I have leaned it out and richend it up etc etc but there is not a spark of life. PLEASE CAN SOMEONE MAKE A SENSIBLE SUGGESTION!!
How is your compression? Maybe a new ring is in order.
Sent from my iPhone using Tapatalk
Compressions really good, probably only put five or six tankfulls through. The only change is that i have started using the premium unleaded as it is improving the running of my Ford.
Check to make sure you did not lean it too much when running last time. May have slightly seized it and stuck the ring in the piston on one spot. Just a thought as it will cause same issue.
