gap on flywheel and coil setting Any Pic's
peebeme
I keep hearing about this gap between the flywheel and coil stuff & wanted to know if any body had pic's or videos on how to do ? My engine want start so I wanna make sure that's not the problem
Best and easiest way of setting the gap is to use a Business Card, undo the 2 bolts slightly and slide the card inbetween the coil and the flywheel magnet, push down slightly on the coil and tighten the bolts up, remove the card and hey pesto it should be good to go..
