gapping ignition coil
Marty Leavitt
I was just wondering if anyone knew the gap numbers for a fuelie 30.5cc engine, I know you can just use a match book, or a business card but they're not all the same thickness. Hahaha please help, I want to use the feeler gauges I use on my dirtbike to check the valve clearance. Thank you, Marty, M. Leavitt
Z.hb71
Manvel, Texas
Polar_Bus
New Hampshire USA
The coil pickup air gap spec is .2-.3mm (.008" - .012"). A typical business card is about .014" and a standard piece of printer paper measures .004". cut 3 strips of printer paper as a layered shim and you are GTG. I tend to favor the higher end of the tolerance just in case you have a slight amount of flywheel runout.
