Gas Devil race 4wd?
I think if you want to go 4x4 and can't spring for an MCD then this would be the go, interesting to see it comes with a buggy body now and also FG baja style wheels. I'm not sure if it would be an issue with those wheels but the MT version suffers from dogbones popping out at the front and needs a simple mod to limit the steering and its cured. The engine, if the same as the smartech version is a 3 bolt head setup and has pretty poor porting, so be prepared to fork out for a better engine, but there are a few pipe manufacturers making pipes for these now so that will help, the only issue is the alloy upgrades are yat to be seen down this side of the planet, so you if bling is your thing you may have to wait to alloy up the old girl. The battery is also a bit avg but is easily replaced with a larger mah number
FYI this is the same as a smartech titan so if you find info on one it is also the same for the carson versions
My friand had one of those
he quickly sold it again and got a baja 5b
he sayed that it is to new so they have many problems
maybe later they will fix the problems, when they hear about them
