gear cover question
I took my cover off bought new gears/shafts/the aluminum blocks/bearings no probs at all with it now :) 1Gal of fuel on the set up now no cover. and all gears are plastic but one.
for the plastic gears yeah run that cover but don't go crazy when you vent the cover! I did and tiny rocks killed my gears. Drill tiny holes
I was thinking about running steel gears with the cover on and sealing it up
with rtv/evenbead and then have a hole drilled on the top of the gear cover that a small rubber stopper... so no leaks and partially fill it up with lube and of coarse blue locktite the nuts on the gears :)
