By the way, is it truly a matter of "not if, but when" in terms of plastic XB gear plate failures? I had another close look at my gears and plate this evening, and this was after the car's 5th tank of fuel. To me, the gear plate and gears look just as good as they did when the car was brand new. Of course, I had lathered the gears in a good synthetic hi-temp grease, and checked the gear nuts to ensure everything was within tolerance.
I'm interested in either upgrading the gear plate to an aluminum MT or 7075RC version if and when my plate fails... or go straight to a 7075RC plate with belt drive once they're back in stock. However, I'm genuinely curious to know how many XBs have had their plastic gear plates fail prematurely? There's no sure way to know; I realize that, but just from searching and reading this forum, it doesn't seem to me that the percentage of reported failures is particularly alarming. There's also no way to truly know whether or not those failures have been the result of user error, poor maintenance, shoddy construction, foreign debris entering the gear train, or a combination of factors.
I did read about one owner who's plate broke after the initial break-in. I think one of the bearing cups cracked, but if I recall, was the result of the D shaft gear nut working loose. I chalk that up to shoddy assembly work though.
So is it truly a case of "not if, but when?" To be honest, I'll be perfectly happy running my XB until the need to replace it becomes evident... which might take some time. I'm not a racer. I don't even bash my rigs that hard. I enjoy the occasional jump here and there, but I'm also happy to do donuts and high-speed runs on tarmac.
Thoughts?
P.S. Most of the reported failures I've seen were back in 2011. I don't know what improvements Redcat made since then. I know the XB I received has what I think are the latest updates; i.e. 10mm axles, aluminum chassis brace block, etc.
