DecentIntoMadness
- Reaction score
- 1
Hi there community.
New here and also new to RCs. Jumped all in with a 1:5 scale baja buggy 30cc 2-stroke. I want to protect the running gear with some sort of lubrication so that it will last a bit longer. The car sometimes go through shallow water and then everything is wet so protecting everything is a bit of a concern.
What is the best here...motor grease used to seal bearings, spray on lithium grease for motorcycle chains, WD-40 penetrating oil to cover a lot of surface and prevent water ingress. It is actually two fold - protect against normal wear and tear and also moisture. I believe I have some mild steel components in the suspension and driveshaft and those will probably rust if not treated.
Any advise will do and I hope it is consistant and I did not open a can of worms with a thousand opinions. Opinions break cars
