Gearing and speeeeeed DBXLe TP 12S
Carlosfandango
New Member
I know volts x if gives a good indication of RPM however I have been following g threads and posts and pulled the trigger on a TP power 845kv 5870 motor which can run on 12S I am now thinking have I got the gearing right. The Dbxle has 48T spur and 16T pinion from.running a castle 800kv on 8S... will this be ok on 12S or do I need to adjust?
I'm running a Leopard 5892 v2 1200kv with an 18t pinion on 8s with stock esc, it's stupid fast but my area is wide open although battery is definitely shorter
I am thinking of going the leopard route as I run the 1340 in my Xmaxx and it's blistering quick I will.have a think.as 12S isn't really making me excited to install.all this kit
