gearing help , with a 29cc and meilke pipe
hongnor
poole dorset
hi again :helpsmilie:,any thoughts on what gearing mine should have as standard ... ive just received it new , but have changed the c/d gears to metal , but did,nt see what the gearing was before .... its a 29cc , its going to be used on dirt .. but want to know , how ive changed the gearing from stock ...:2guns:
Standard as you know is 16T on the pinion and 48T on the spur. I would think if you need a good acceleration and decent top end go for a 18T pinion and a 46T spur.Sounds good to me but I'm sure the other 1/5th scalers will advise you.
Good luck.
James.
