what options are available to lower the overall gear ratio of the rampage mt??
i know mcd has or had a 24/36 main gera setup but what about options for reducing the other 2 gears on that mount?
what about a 20/30 setup over the 25/25
as well what about the mid diff and f/r diffs??? front and rear diffs from what i can tell are 16 12 and the central diff is what 10 and 30????
mid diff is what???
and what is the standard rampage mt end gear ratio???
what i am looking for is info more then any thing i am looking to get 1/5 scale but i want to gear it low enough for some decent off roading (not full scale rock crawling) and well after trying out a 5b, 5t, tt, and a mg murader (yes i know out of those only 1 was 4wd) but there all geared imho for racing and not what my intended purpose would be.... can any one help me out? or point me in a direction other then in a circle lol
my goal would be a top speed of around 12-15mph @ full throttle if @ all possible i will most likly be running a honda gx35 (better flatter torque curve) the honda motor would get a straight pipe (gx35 is a 4stroke)
http://www.honda-engines.com/engines/gx35.htm (a straight pipe over the emissions bullshit should increase the revs by 250-300rpm+ as well as running race fuel)
mid diff is what???
