Gears locked up
Gene74
New Member
I was doing donuts for my son in the grass I let off the throttle the car stopped I went to accelerate t did not move the engine ran fine but not would not move took off gearbox gears are locked what could that be please somebody help
its gonna need a strip down dude to find out........:)
I agree with 'evssv'. You have to get to your transmission gear-cluster, and your drive-gear unit. Once there, CHECK TO SEE IF A ROCK IS CHOCKED BETWEEN YOUR DRIVE TRAIN. Then, CHECK FOR MISSING 'SET SCREWS' (GRUB SCREWS). Also check your spur gear to see if it is broken with bits that has caught in your drive-train. Do it happily. You'll get to know your vehicle better. Hope this helps.
