gears r bad
ALL OF THEM? stoooop. (drive gears). is their on upgraded gear plate? if not you NEED one. thats standard equipment. comes free when you buy a new one from rob. with the stock one the bearings heat up the seat and give the gears a shimmy. cousing them to melt. redcat fixed that with the upgrade kit. to check, look behind the gear plate where the clutch bell is and if there is a large alum bearing race, then its upgraded. if not you need to get the upgrade kit. also check the bearings too.
I just got the upgrade kit. I need to change out all the gears before I put the upgrade in it , is there any better ones available. can I change the gearing to make it faster. thanks Kryptonite
mcd gears, 25/25. can also get the 27/33 mcd gears as a set from rampagehopups for gearing changes.
Rob also offers metal 25/25 gears.
also, see the sticky for gearing options at the top of this section.
