glenn201
- Brazil Indiana
how long do the steel gears last do they hold up a while or should i keep a spare set on hand
I had a bolt vibrate loose from the engine carrier plate, all the way out and my transmission and gears became a washer machine for the bolt. It finally wedged
between the plastic and last small gear and was ground into the base plate.
I could not believe that it did not do any damage to the gears. They still looked new.
Tough gears for sure.
cheers,
HD
i had one bolt come out tore up the bolt didnt hurt the gears lol these gears are tuffI had a bolt vibrate loose from the engine carrier plate, all the way out and my transmission and gears became a washer machine for the bolt. It finally wedged
cheers,
HD
Is it best to run them dry or with some type of lube?
