So Cal if you tried out the Turtle system with the baja element you would be floored with the change in preformance, and the best part is the filter is out of the way of the crap coming off the front tires, and the surface area of intake air is about trippled. I have it on all 3 of my scalers, the difference is just unbelievable and it shows in how much tuning it takes after install. only had to remove a couple of bars on the side of the cage for a perfect fit, no effect to the body. Dude I was running in mud and puddles that would have wiped out a side filter, the truck was covered in mud and the filter was clean and dry. That is the 2 main plus's preformance and location. for 69 bucks I don't know of any hop up that gives so much change in power and the ability to go through anything and not harm the motor, just my .02 Good luck.
