Getting ready to make my 7075 RC order, Couple Questions...
  • Thread starter Thread starter Keith81
  • Start date Start date
K
Keith81
Guest
I am ordering the following from 7075RC for my XBE, what spur's and pinion's should I get as well, Yes more then 1 spur and more then 1 pinion...
Anything else I need to get along with this order ??
Thanks in advance as ALWAYS!
Keith
Stuff I'm ordering, Will be running a Leopard LBP5692-1340KV 4 pole motor :
Motor Mount Package Deal (need to know what spurs and pinions to get)
(8) 22mm x 6mm Ball Bearings
Front Bearing Holders
Rear Bearing Holders
C-Hubs
Ol said:
How many cells are you planing on running and what are the specs on your ESC?? Also, are you running stock tires?
I am using the stock ESC (for now until I can afford a better one) and I am using proline trenchers on baja rims, using your adapters already for those :)
I am using Venom Power 20C 5000mAh 11.1V LiPo Batteries... (for now as well)
Can you reccomend a good set of lipos' too ???
Hi man i ordered my stuff from 7075rc all the stuff from 7075rc except the wheel adaptors should be here soon
I am running all stock tires so the pinion gear im getting is the 10 Tooth
and the spur gear is 48 tooth obeast recommend this to me since i am running stock tires and esc
my motor will be here tomorrow it is the leopard 5692 with the 8mm Shaft
here is a good battery choice look here
http://www.hobbypartz.com/77p-sl5000-3s1p-40c-3333-hardcase.html
these are 3s Hard Case Lipo Batteries With a discharge rate of 40c all for $38.00 ea
Keith81 said:
I am using the stock ESC (for now until I can afford a better one) and I am using proline trenchers on baja rims, using your adapters already for those :) I am using Venom Power 20C 5000mAh 11.1V LiPo Batteries... (for now as well)
Slasher said:
Hi man i ordered my stuff from 7075rc all the stuff from 7075rc except the wheel adaptors should be here soonI am running all stock tires so the pinion gear im getting is the 10 Tooth
I will go with a 10 t and a 48 spur, but I also want one extra set to change out to have choice, just not sure what to go with....
appericate the help bro!
7075rc
I would stick with the 10/48 setup for now, maybe go to an 11or 12 after upgrading your ESC and batterys. If you go to 8c after the ESC upgrade then stay at 10/48
Those trenchers are bigger than stock so turn down the ESC to the lowest setting to give it a break.
Thanks for the reply Ol' Fart, I appreciate it...
Doing my order real SOON !!!
Finally placed my order, I cant wait for my stuff to come in!!!
Yes!
